drivers side door
connectingbar
New Hartford, NY
Anybody have a driver side door laying @ in central NY? Mine just started to have problems with the outside handle ( wont unlatch but inside handle works? also when I roll down the window it wont roll back up. I would rather swap it out for another working one. I live in Utica ny
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
That is way more effort than needed. The handles go bad. Take it off and find a replacement. I have a good take off if you can't find one.
littlebob
26
Baton Rouge LA
As far as the door latch goes, Are you sure you don't have it in the locked position inside? If your doors are solid(little rust) I would think about trying to fix it. I broke a few bolts when removing mine. If you need some parts for yours I might have them. PM me.
littlebob
Barrman
1,730
Giddings, Texas
I agree. Leave the door on the truck if it is rust free and fix the window/latch mechanism. It isn't that tough. I went through 4 sets of used hinges before I found a set that I could actually get apart and put back together again. Plus the broken screws that RJ wrote about.
jatonka
87
Ephratah, New York
I am in central NY 30 miles East of Utica, I have everything you need, any way you want to do it. if the truck is on the road, PM me, then bring it down, I'll fix it. JT
connectingbar
New Hartford, NY
Thanks JT, I figured out the door handle. I hammered down the tab that it turns against and it works fine now. I will dig into the window soon. I would bring it down but it is apart right now ( putting a new IP in) While I am at it I am going to install a M151 heater and a tank style engine heater. Just waiting for some more wiring and some searching on where to hook up the hoses to the engine. I also am going to create a heated arctic battery box and install in the cab.
I hope to be down soon for the hard top when I get the ok to continue work at the school:roll:
