Rattlehead
- 3
- 18
- Michigan
I was doing some more work on the deuce today, and in removing the alternator I finally got fed up with messing with the nut and bolt arrangement within that hard to reach area. I took off the mounting bracket and welded the nuts to the brackets. Yeah, I know about welding to cast iron and have done it before with varying degrees of success, but it took pretty well with just a mig weld, no preheating. Now it is just a simple install of the rear bolt working from the top, and a simple install of the front bolt working from the bottom. One wrench and one hand is all you need.
