Engine oil cooler lines resting on exhaust manifold
Gamble
340
Los Angeles, CA
Does anyone else have this strange issue? The [engine] oil cooling line(s) rests on one of the exhaust pipes coming off the engine. The line was being melted through by the heat of the exhaust pipe. I wrapped it in heat resistant material but I thought this was insane. Has anyone else looked behind their doghouse and discovered this? It's in the lower left corner of the doghouse at the bottom. Actually right below the doghouse on the left side.
Action
1,556
East Tennessee
Trans cooler lines are on the RH side of the engine.
The red circle in your diagram pic is of the LH side of the radiator. The hoses in that diagram are the engine oil cooler lines, as seen in the heading at the bottom of that page. Those oil cooler lines (in the diagram) run down the top of the frame rail and end up by the oil filter.
What engine do you have?
Action
1,556
East Tennessee
you might want to straighten that bent metal, or your doghouse may not seal well. Heat and noise levels will be higher while driving. Maybe other stuff is damaged in that area? Inspect your doghouse seal for damage, too.
Gamble
340
Los Angeles, CA
6.5 Non Turbo
Action
1,556
East Tennessee
I guess either no one else has this issue or is unaware of it.
Put the hoses where they are supposed to be. In the diagram you posted, you see the bracket (#15) that bolts to frame rail near the steering gear box. Then the next bracket down the line is on the motor mount near the frame rail.
the hoses do not run next to the exhaust.
Gamble
340
Los Angeles, CA
The hoses don't run next to the manifold? Hmm guess I need a pic to see that. Seems my hoses have been that way since receipt. Interesting.
Action
1,556
East Tennessee
I forgot that you have a different manifold. TM 9-2320-280-20-has decent pics. If you can’t get the up off the exhaust, see if there is any slack up front to allow the hoses to be pulled back. All clamps would need to be loosened.
my bad on my directions. The TM mentioned zip ties. I dont know if those are important.
86humv
498
Texas
There are different length hoses with angled ends...maybe they got installed in the wrong order and clocking of end when tightening.
19,605
And by the way Gamble there are stainless steel zip ties. That way you don't have to keep repairing the plastic ties every few years as the heat and old age work on them.
