Exhaust help
zak
-4
Ortonville, Mi
I'm trying to put my exhaust back together in the M342a2 that I just bought at auction.
The exhaust was missing from the flex pipe back. I'm just working from the pictures in the tm 9-2320-209-20p. I've assembled everything I needed working from fig 47. But for the life of me I can't see how part #29 fits in. The diagram show that it has it own bolt at one end and shares one at the other. I thought it went from the clamp #18 to the clamp #2 but it does'nt line up and that end has its own bolt. Where am I going wrong?
1,128
I think this picture shows #29-it is a bracket running from the exhast clamp to the inner fender.
zak
-4
Ortonville, Mi
I dont have any holes near here. Must have been a change somewhere thru the years. You can just see the top of the brace in #5 and the bottom bolt in #3. Mines a 73 AM General. I knew I would find the answer here. Anybody need a brace?
WillWagner
2,610
Monrovia, Ca.
I don't have the bracket from the feder to the pipe either. I would think it would cause problems when the engine torques over or the truck flexes on rough terrain.
FreightTrain
Banned
2,730
13
Gadsden,Al
yea,that bracket runs from a hole in the cab to the now flapping inner fender.In the Non turbo trucks there is a chunk of sheet metal to makes the connection.I had to cut mine off.It was about 6 or 7" tall and did a 90 degree to the cab to a single bolt.They could have positioned the picture a few thousands of an inch off from the clamp bolt....But like nearly all goverment kits,they were drawn by complete idiots that never have even touched a deuce or a wrench by the looks of it......
FreightTrain
Banned
2,730
13
Gadsden,Al
oh yea,your truck already has that bracket installed.You can see the upper bolt just over the flex pipe connection in picture 3 above(or Picture P1010005.JPG)
