Fiberglass top questions
Rrent
142
Texas
The areas where my top94CB27EF-942D-4EF2-9612-D998155CDE68.jpegA0C3A176-876A-44A3-91D1-3615332678DD.jpeg was painted black (camo pattern) are in pretty bad shape- I’m guessing sun damage. The fiberglass fibers are exposed. Should I repair- if yes, how? Or replace - if yes, is civilian top exactly the same. I found a top close and affordable.
18,804
The areas where my topView attachment 844049View attachment 844050 was painted black (camo pattern) are in pretty bad shape- I’m guessing sun damage. The fiberglass fibers are exposed. Should I repair- if yes, how? Or replace - if yes, is civilian top exactly the same. I found a top close and affordable.
You can go with GelCoat fiberglass resin and maybe a layer of fine fiberglass fabric. If you haven't done it before, it takes time and effort and a lot of sanding and SCRATCHING and the wearing of a mask.
I can't answer the civilian question - but most of the body of the truck is the same (Civy vs Military)
nyoffroad
601
Rochester NY
The top can be fixed but in the one pic it looks like the front seal has been boogered up and leaked. Now might be the time for new seals and a new top, yes the civvie top will bolt right on. Make sure you all the seals and watch out for the 'hidden' bolts! IIRC there is one bolt on each side in the back that goes from the bottom up and in the front I think there's one behind a small metal plate.
cucvrus
9,552
Jonestown Pennsylvania
If you were closer I would have a replacement top for a small fee. I have been cutting them up and putting them in vehicles going to the shredder. I have 4 or 5 M1009 tops and a 1991 K5 with shoulder belts attached to the top. They are all leaving here soon as possible. I only need 1 of them at this point. But I would sand that top with80 grit and see what happens. That can be fixed but a replacement top would be easier and better. Good Luck.
