Flashing wait light
jim1131
35
Illinois
I hear a clicking noise coming from the start box even when the ignition switch is in the off position also my wait light is flashing . Should I assume that the start box is going bad? The truck starts and runs with no issues and I believe the box is a Nartron yellow label
Mogman
9,213
Papalote, TX
One of the PCBs that I swap in and out of my HMMWV during maintenance sometimes thumps 2 or 3 times after shutdown.
Other than that it works fine, but I would say that is not "normal"
I had a cheap electric fuel pump, one of those "thumpers" that would sometimes not let the PCB (multiple PCBs) shut the acc power down, that was a little strange, a diode across that pump may have fixed that problem but I replaced it with a real pump.
