Found fuel in the crankcase and a hard start
Chitangi
Athens,Ga
Hey guys !
I recently bought a 1967 Kaiser and I have some issues, its giving me a hard start and also I found some level of fuel in the crank case besides the loss of power, its also giving me some really black smoke and white..hopefully i can get some help this is my new project.
dmetalmiki
1,442
London England
Change out the oils. Check the head gaskets. Check the turbo (if fitted).
Look for oil in water. (and water in oil). report back.
Also more details about your truck with pictures.
The King Machine
78
Vancouver, British Columbia
The oil in my crank case was due to my injectors being bad (wore out nozzles), weeping fuel into the cylinders then washing down to the crank case. The residual pressure in the post IP injector lines would drip fuel after shut down. Would also explain your smoke issue.
Other possible ways to get fuel in the crank case include the FDC, Flame intake heater, and the IP
I eliminated the FDC and flame heater also to be safe.
Jeepsinker
236
Dry Creek, Louisiana
Do not run the engine anymore until you get the fuel in oil issue fixed. Fuel density compensator and hydraulic head o-rings are the most common causes of this.
gimpyrobb
dumpsterlandingfromorbit!
27,707
339
Cincy Ohio
If its hard to start and smoking, pull the injectors and have them pop-tested/rebuilt. Thats your first step. Then I'd have the gaskets(and O-rings) in the IP replaced. Finally, I'd delete the intake manifold heater and remove the FDC from the fuel loop.
