Front axle traction aid
ODdave
lansing michigan
So I am thinking for ease I am going to put a drivers side drop front axle in my 1028. I figured I would see what your guys thoughts are as far as the differential. Right now it has a trac loc.
Would you run,
Trac loc?
Power loc?
Detroit locker?
Its not a DD but I do plan on driving it ocasionaly, My goal is to take it up to the U.P. and go camping / wheeling.
WARWAG
Driversdie drop front axle? Not sure what you mean.
As far as a traction device I would go with either an OX Locker or and ARB Locker. Both selectable. The OX locker is manually engaged from inside the cab with the pull of a lever (attached to a cable). The ARB is a simple flip of a switch which actuates an aircompressor for about 1/2 a sec and wholla youve got a locked up front axle.
ODdave
lansing michigan
Drivers side drop = driveshaft on drivers side insted of the pass side.
I understand that the OX and ARB are great but I allready have the other three.
WARWAG
If your going to be driving her on the street much then a limited slip option would be your best option. Not sure if I would want a locker on the front during the winter time on icey roads. Mine has I believe a Trac Loc which if that is indeed what it is then it works great off and on the road. Mine is a stock M1028.
ODdave
lansing michigan
Eh, no. My best option is Not to spend another $1000 on this truck for a diff. It is to use one of the 3 I listed which I allredy own, I was just curious to peoples opinions about those 3.
Buying a house right now and just dont want to be hemoraging money on this truck.
ODdave
lansing michigan
I should re-word, I would prefer NOT to spend another 1K on this truck as it could be better spent on the house I am purchasing. I would like to use the best of the 3 diff's I allredy have.
porkysplace
1,485
mid- michigan
95 % of your driving on paved roads the hubs will be unlocked , on dirt roads it doesn't matter . I always liked my International travelalls with all-wheel drive on ice and snow , you just about can't get one stuck in the snow.
Matt1031
Atl, GA
For ease? I don't understand why you would want to put a Ford Dana 60 (driver side drop) under an M1028 when the Chevy Dana 60 that's already under there fits perfectly.
Awful lot of work for not much gain. You want a high pinion that badly?
ODdave
lansing michigan
Im not puting a high pinion in it,
Read my sig line. I want drivers drop so I can run 4in exhaust. It is a very tight fit with the pipe and drive shaft on the same side. And looks stupid with nothing on the drivers.
