rdixiemiller
- 3
- 38
- Olive Branch Mississipi
All
Anyone needs some front flanges desplined, send them on to me. I cut 4 hubs today, takes about 1/2 hr each. I am using a 1" carbide insert boring bar and opening them up from 1 5/8" to 1 7/8". I don't have to remove the expansion plugs on the outboard side, I set an indicator and bore to within .050". That is a good thing, as all 4 used flanges I bored had some serious dings around the plugs, they would not have been easy to get out. I would also have had to use the boring bar and clean up the recess before a new plug could be installed (freeze plug will fit). For the front, all I am doing is boring. For the rear conversion axle I am working on, I am bushing the hub to support the outboard end of the double splined axle. I am using an oilite bronze bushing, and allowing .030" clearance.
I am pretty sure I can do these and barely mark the paint where the 3 jaw chuck grabs the flange.
Price: You pay shipping out, I will pay shipping back. Just throw in some odds and ends of deuce stuff that someone rebuilding one would need. You can also just owe me a favor, I accept that as well!
I figure 3 day turn around. If someone is in a hurry, I can probably do 2 days.
This gives me a chance to practice my machining skills and have a little fun!
Just for information sake: The hubs are a mild steel forging, not hardened. They cut extremely easily with my setup.
I see no reason not to be able to do 5 ton hubs, if anyone wants that done. I would just have to put on the 16" 4 jaw chuck to grab them.
