Front Shocks
Loose Deuce
South MS.
I think I may have the wrong type front shocks, or the wrong rubber bushings. the shocks fit loose because the rubber bushings are not large enough to swell out when tightened. Its easy enough to correct but I wanted to replace the shocks anyway. Does anyone know a cross ref. number for a replacement? I cant find any NOS surplus shocks, and I have my doubts if they do any good anyway. :roll: :roll:
Dieselsmoke
CA/NV
Monroe, but dammit I can't find what I did with the flippin number. They make a nice gas shock in that size that works well....gotta paint them though, they come in yellow and blue. I'll look for that damn number.
cranetruck
75
Meadows of Dan, Virginia
Leaf springs have built-in damping by the friction between the leafs. The shocks are needed to dampen higher frequency vibration only. The front shocks on the deuce are double acting and have approx the following ratings (rebound/compression) : 320/170 in lb of force. A suitable Gabriel number is 83400.
Never lubricate leaf springs, that would effect the damping.
Westech
CPL
6,104
207
cow farts, Wisconsin
yes monroe !! I have them on my deuce I just put them on!! OMG what a huge help. No more chopping front tires, does not want to flip ove in a corner but I dont think I have the number I will try to find it.
cranetruck
75
The p/n 83400 is in the Gabriel "2003 Gabriel Commercial Ride Control products".
There are other ones that may need slight enlargement of the mounting holes, such as #83102.
I had the number crossed to a Monroe, I think and I picked a bit higher ratings to compensate for the 11.00x20 tires. I'll check the deuce later today. I know I had to bore out the mounting holes some and the rubber mounts were larger than the mil issue.
cranetruck
75
Checked the shocks on the deuce and they are ArvinMeritor (Gabriel parent company), made in Canada, p/n T112-7SA.
I gave the store a Gabriel number, don't know which, 83102, 83103, 83400 or 83456 and they crossed it to the ArvinMeritor. The mounting holes had to be enlarged, I used a reaming tool and it turned out to be an easy job.
They look good and seem to be doing their job. With the new shocks and the rear stub axle removed, the tires look almost new after 6,000 miles on the highway since installed last year.
1,128
So do the Monroe 66903's require enlarging the mounting bracket opening? I'd prefer not to do that........I'd like a quality civvy gas shock that bolts up......
emmado22
147
Mid Hudson Valley NY
So whats the bottom line on replacement shocks? Civy ones are fine, I'll enlarge a hole or 2 if I have to.... The savings on the 9.00 x20 tires is well worth it. Whats a good part # I can get at the auto parts shop?
cranetruck
75
Armada, the shocks will dampen high frequency vibrations and may not be the culprit in this case. The major cause of tire scrubbing is the fact that the rear axles are coupled together without a differential. They will push the truck straight forward and fight the steering effort, duals more than singles.
ken
25
Houston Texas
I installed the monroe gas magnums. I'd have the read the shock to get the #. But man what a difference. Cupping of the front tires stopped.
