Fuel Lines Diameter
Explorer0863
27
Orlando/San Juan
Hello everyone. I am making my own fuel lines. 1963 M37B1. I have several TMs but I can’t find any reference regarding the line diameter. I know they sell a kit, but where is the fun in that? Any of you know the diameter?
INFChief
1,343
New York
Do you have part #’s or Native Stock Numbers for the fuel line?
INFChief
1,343
New York
The first thing I should have mentioned was whether you’ve looked at the extensive TM collection here?
INFChief
1,343
New York
I have at least 5 TMs. I didn’t find the diameter in any of them. Do you know the diameter?
If you can get me the part # or NSN then I might be able to find it. Also, most parts TM’s will show a “BULK” part # and may include sizes. The bulk # is typically for parts that could be made by unit mechanics. Making a fuel line or brake line would not be uncommon back then.
Canadianz
54
13
Ontario, Canada
I believe the fuel lines are all 5/16, if my memory is correct. I did the truck with a 20’ roll of cunifer lines. Definitely practise making the flares, as the nickel copper stuff is softer, and requires a more gentle approach than steel.
Edit- you can also buy stainless steel spring armour if you want too. The end result looks like stock but will outlast steel.
Cheers
Rob
Explorer0863
27
Orlando/San Juan
Cheers
Rob
Thanks for the info. Just found the spring armour on Amazon, of all places.
pjvargas
Ramona, CA
Army TM 9-8030 Operation and Organizational Maintenance ¾ Ton 4x4 Cargo Truck M37 May 1955
Paragraph 141. Fuel lines and Fuel lank Vent Lines
a. General.
If replacement fuel lines are not available as assemblies, use 5/16-inch seamless tubing, flexible conduit, and 5/16-inch inverted flared tube fitting nuts. Double flare the tube at each end, using a flaring tool.
NOTES.
The double flare is a 45-degree flare, not the more modern 37-degree (single) flare.
You can buy the straight tubing in different lengths at NAPA, double-flared on both ends. This is nice because when you cut it to length you have a nice factory 45-degree double-flare on one end and you only have to flare one end.
Tubing (in rolls which can be a bear to straighten out for use), fittings, and armor is available online at www. inlinetube.com.
Make sure all your fittings are for the 5/16" tubing and have internal or external 45-degree flares.
If you're going to do this yourself you'll need some tubing bending tools as well as a quality flaring tool.
18,782
a. General.
NOTES.
Agreed and don't buy a cheap HF double flaring tool.
Spend a few bucks and get one that will last as long as you.
Mine is over 40 years old now and it still works as well as the day that I bought it.
87cr250r
1,830
Rodeo, Ca
Ridgid makes the best hand flaring tools.
If you don't need a case, this is a good deal.
Otherwise 33927 comes with a case for $40 more.
