- 2,301
- 880
- 113
- Fargo ND
Your going to see this attached to another post sorry about that it was my mistake!!
Here is the reason I am asking for thoughts! I replaced the thermostats on my 88 M977 and all the cooling lines and all went well replaced all the hoses since I was in that deep also. Well everything is done the cooling system is full and I go to shut the truck off and it wont shut down, I see my ammeter move when I hit the shut down switch but the motor keeps on running. On top the engine attached to the right thermostat housing there is a can looking solenoid that pulls a rod that goes across the engine to about the middle of it and it attaches to part of the throttle, its NOT activating, I know its getting power by movement on the ammeter but no movement. I disconnected it and shut the engine down moving the rod by hand.
This can looking fuel shutoff, is it a problem item, is it a repairable part or is it a replacement item? I am going to remove it tomorrow and tear into it and see whats going on. Any thoughts prior to that would sure be appreciated!
Thanks Much
Karl
Thanks Much
Karl
