Gen 1 Light comes on when heater switch is turned on
w5ood
Houston / Texas
Heater worked fine this morning. After work you can turn on the heater fan switch but the fan does not come on, but the GEN1 light comes on. Any ideas? Im looking through the TM34 at the schematics just wondering if someone has seen this before. I feel like its a short somewhere.
cucvrus
9,603
Jonestown Pennsylvania
Not a short. I am thinking that the switch and pigtail on the blower switch are melted and making poor contact. A common issue when the switches get older and make a poor connection. Check that out.
w5ood
Houston / Texas
Ok Ive read a few things now and I see what I need to look at. Thanks for the advice. Ill check resistor and switches and pigtail.
hokie8358
backwoods ,virginia
I’ve got same problem and just encountered this issues! What did you find out on your dilemma? Thanks
w5ood
Houston / Texas
I have not had a chance to look at it. But from what I read it sounds like it’s either the fan motor the resistor on the back of the fan housing or the switch that turns it on. I’ve looked online and all together it appears to be less than 75 bucks. I’ll probably replace them all.
dougco1
548
Cooperstown NY
Check to make sure that mice have not nested up in the squirrel cage in your fan. You can reach up with your hand through the outside air duct on the passengers side. Pull the damper cover off and reach up to the fan and see if the fan spins. I had that happen to me, the mice packed their nest around and in the cage preventing it from turning.
muttly
44
13
Cloverdale IN
I had the same issue with my m1009. Gen 1 lamp just barely glowing with fan on, I could only see it at night. A few days later the Gen1 lamp came on bright and stayed on. I found the fusible link burned for Gen 1 and it looked like it had been slowly roasting for some time. Gen 2 fusible link was questionable also so I replaced both fusible links and the problem went away. I'm not positive the fusible links caused the problem because at the same time I cleaned all positive and negative connections on the firewall. A wise man once said "if it's electrical clean it, if it's rubber replace it"
hokie8358
backwoods ,virginia
I did replace fan with a good one that I also checked before I installed it, also the resistor beside it with one tested and good!
crank truck , hit fan switch to medium speed, no fan still and gen light 1 on ! Cut switch off from fan, gen 1 light off! All alternator functioning as they should! Fuses are good, I am thinking something from heater controls themselves ! Unreal!
hokie8358
backwoods ,virginia
This is a damn nightmare lol
