blackhueys
- 4
- 18
- mn
Since alot of people seem to be encountering this I will tell you what finally did the fix for me and only cost 25.00. First I had the Alternators rebuilt helped some but problem still there fan on high etc. Well got bored yesterday and pulled them out and tore them down found out that the shop never replaced the diode trio or the voltage regulator, well went to the local parts place and picked up two of each and so far no lights at all. the voltage gauge stays put right in the middle of the green regardless of what I do all lights on fan on high or low rev it up and down nothing makes the gauge move anymore! Voltage test front battery running is at 14.50 volts rear battery running is at 14.45 volts and together about 28 volts constant! just thought I would share my fix and the alternators really are not that scary once you get them apart and see.
