Glow plug control box question
Thumper580
210
Virginia
Excluding the Camoteksystems box, I was wondering if HMMWV's with the 400amp alternator would use any special or distinct smart start box and tsu. My M1123 A2 came with a 400amp alternator so I assume it has the upgraded wiring, etc. as you can't pass 400amps through the control box? Is this correct or am I confused (again)..... Looking at what my options are... or aren't. Thanks.
Mogman
9,216
Papalote, TX
The 200 or 400A alternators have little to nothing to do with the EESS box but for the fact the EESS box excites the alternator you are good.
The only real difference is the 400A has two large cables going to the battery instead of one (I believe the "extra" cable actually goes to the starter, same smell)
Thumper580
210
Virginia
So then any mainstream startbox/tsu is acceptable?
Mogman
9,216
Papalote, TX
Yes as long as the TSU matches the EESS/PCB, some EESS boxes do not need a TSU
Milcommoguy
2,176
Rosamond, CA
All the boxes excite the alternator in the same way. Yes, the 60 Amp alternators output does pass thru the box. (another HumV brain fart)
All others alternator outputs are direct connections to the batteries with the big fat wires. Technical description.
So... you're not Con-Fused, CAMO
Camoteksystems.com
