H2 Wheels on M1101?
4,744
Bolt pattern should be the same. They're just a little shorter. I'm not sure on the backspacing though. Probably will stick out a little more.
Expendable
SoCal
I do not have an M1101/2 but if the hub is similar to a Humvee/H1s then you're going to need to bore out the hole for the hub in the H2 wheels since they are too small.
