Eliteweapons
- 5
- 18
- Baltimore Maryland
We are trying to install the hard top on my truck but the instructions are mostly destroyed. Already removed that plate on the cab cleaned it up and painted that. Also repaired some rust on the windshield frame and painted that too. Most of it is common sense and we have it almost complete but ran into a few snags.
1) It appears that the windshield wiper motor arm guards need to be removed because the top sits directly on that top rail and the gasket needs to be flush.
2) I can see some mention (on the remaining paper product) that an existing bolt hole needs to be drilled out but in the bottom of the window there appears to be a rivet. Does that get drilled out? it also says to drill the hole 17/32 which is bigger than the bolt head.
Does anyone have a copy of the instructions that is legible? The only thing I can find in the TM shows just removing and replacing the top not a new install.
