Has anyone removed the turbo from a deuce just to safely "blow smoke"?
gimpyrobb
dumpsterlandingfromorbit!
27,785
747
Cincy Ohio
Well, originally, they were only considered a "clean air kit" to remove some of the smoke of a N/A motor. Most that have a turbo have been tuned a bit more than 5hp.
I think it would be easier to just turn up your fuel(for more smoke), but taking off the turbo could work too. Then you'd have to change the exhaust system, what a lot of work just to get some smoke.
Its your truck, do as you please, but I bet your let down by the results.
1,814
To get the full effect of your desired result, duct the exhaust into the cab or at least have it dicharge so that it blows back in your face.
nukem
15
Decatur,Al.
@quickfarms, one of my illustrious in laws with a 72ish Dodge with dual stacks had a pump with a switch for atf injection. Really:((
Lots of white smoke.
FloridaAKM
392
Gainesville, Florida
Mine used to smoke when I ran wmo in it, but it caused it to not run smoothly. Now with straight diesel & a little TCW3 for injector lube, she only smokes when you really get into the injectors with a heavy load or going up hill!
