Having trouble adjusting the alternator
acesneights1
21
20
CT
My deuce was only at 24v so I tried to adjust the regulator by increasing the voltage adj. it went 1 click and did nothing, 2 clicks I could actually hear the engine lug down a little, it was putting out 28.5v and I would hear a screeching almost like loose belts but belts are tight and in good condition. When I backed of the adj, back to 24v.
got me stumped.
acesneights1
21
20
CT
Yeah , I was wondering about that too because Inhave adjusted a few of these and never had one feel like it has clocks to it but this one did and it looked slightly different than others I have had so figured maybe that's how this one is. The Troubleshooting TM did not really address the issue I'm having. This one will charge but can't balance it. It's either too much or nothing . Maybe the regulator pot is bad and that's why it feels like it's clicking. I guess I'm yanking it tomorrow.
i would replace the regulator but the noise coming out of it whe. I did get it to charge bothers me. I may take it to a shop and have it tested.
frank8003
4,973
Ft. Lauderdale, Florida
Save your hands and just remove the entire bracket and generator from the block with the three bolts attaching it from the block.
But then you already knew that, I did not.
The plug or cap to get to the adjuster is supposed to be torque 35 inch pounds but mine was locked in there at > 35 foot pounds and I had to cut off the 10-32 cover plate screws to get in there.
It would be interesting when you find the front bolt generator to bracket with a cross cotter pin in it and a special locknut that noone can get to.
Especially is fun with no Soldier "B".
but then I followed the TM as I understood it. Oh well.
Sometimes I think I can fix things.
gimpyrobb
dumpsterlandingfromorbit!
27,785
747
Cincy Ohio
24.5 should be about right for charging. Maybe you just got a bad "pot" on the regulator that is causing the clicking. I've found it helps "some" to pull the alt, take the regulator off the back and hose it down with brake clean. Then I hit it with pressurized air to MAKE SURE its dry before putting back on. The alts can really collect debris inside that doesn't do them any good.
rustystud
2,387
Woodinville, Washington
Actually the correct charge rate on a 24 volt system is between 27.0 and 30 volts. 30 volts is usually only on special equipment as normally this much voltage will cook your batteries out of water really fast. I always set mine at 28 volts. Now the new "MAT" style batteries need it to be exactly at 28.5 to 29 volts.
FloridaAKM
391
Gainesville, Florida
My Deuce runs @ 28.5 & all is good @ the gauge & the Fluke. The LMTV runs @ 25.0 on the truck gauge when you start it, & slowly goes into the yellow zone after about 10-15 minutes. The Fluke says it is 28.5 @ the slave port. I don't trust the gauges on military trucks, especially the FUEL gauge.
BT3583
85
New York
Hi all I know this is an old thread but what the hell. I think my generator is shot, when checking voltage at batteries I get 25 (new batteries). When checking at the alternator I get 23.5. I disconnected the positive lead from generator and left exciter wire on, started truck and check from the power to ground and got zero, actually had continuity. Can I assume she’s done? Also, can the adjuster screw on generator be turned to much, mine just turns feels loose. Thanks!
