Headlight wires.. Which one does what.
Thumper580
210
Virginia
I got a pair of 24volt high intensity headlight units 7" diameter. The three plug ins are in a upside down pyramid shape... Upper left, Upper right and bottom.
Wondering which one is hot, low and high beam. Thanks.
HoveringHMMWV
1,037
AL
Milcommoguy
2,170
Rosamond, CA
That 16 is a 91. What ever happen to the guy that had all the trouble with the blinking flashing headlight??
Not a typo, CAMO
papakb
1,184
San Jose, Ca
These connectors are called Packard connectors and are commonly available on Ebay or from places like Erik's Supply. As Cam says, there is no #16. #17 is the high beam line, #18 is the low beam line and #91 is ground. The schematics for the trucks are located in the back of TM 9 2320-280-20-3. For 90% of the truck wiring they're all the same. The main differences are with the higher amperage alternators, AC units and special purpose bodies like the ambulances.
Thumper580
210
Virginia
So, using the same orientation of the stock headlight the plugs in the brighter headlight would be yellow=91, blue=18 and red=17....Yes.
Milcommoguy
2,170
Rosamond, CA
Maybe ?? Roll the dice................. Are they 24 volt? Any paper work? Made where? Feel lucky?
Never been lucky in Vegas, CAMO
TOBASH
3,397
Brooklyn, NY
Dude, easy answer. Get 2 wires and connect to your battery or a 24V source. Then connect to the leads you identified in the order you described to see if you're right. Then post the answer.
Best,
T
Milcommoguy
2,170
Rosamond, CA
With those lights, one should be the brightest kid on the site. LED or incandescent, hard to tell. I did read bulb?
Glasses on to read between the lines, CAMO 😎
