redneckitguy
- 9
- 3
- Texas
The Govt never converted a truck from a 3 speed to 4 speed during a reset, the 6.5 is the standard replacement because the Mfg stopped producing the 6.2, the 6.5 you have is as it’s referred too in all TM“s as “Detuned”.that clears up the R1 thing. I was trying to figure out the difference in A1 and R1.
So they swap motors but not transmissions. Thats an odd upgrade.
I will look at that. The 3 speed is kind of a bummer but not the end of the world. I just need to figure out why it kills the engine when its put in gear.You will probably find a NP242 T case, it looks like when they upgraded these it included a 6.5L and the later T case
I have confirmed it is the detuned 6.5. im not running on a highway or anything so im not worried about that. Another truck with the turbo and 4 speed may be in my future but this is just a project for me to learn on.The Govt never converted a truck from a 3 speed to 4 speed during a reset, the 6.5 is the standard replacement because the Mfg stopped producing the 6.2, the 6.5 you have is as it’s referred too in all TM“s as “Detuned”.
ANY truck getting a new or rebuilt motor for that platform would get a 6.5....if it got a new transmission, it be a 3 speed TH400.
if putting it in gear kills the motor? The trans is bad…the torque converter is locked up.I have confirmed it is the detuned 6.5. im not running on a highway or anything so im not worried about that. Another truck with the turbo and 4 speed may be in my future but this is just a project for me to learn on.
I have driven them, mostly rode in the back of them, but never worked on one. This was a project opportunity. I plan to start taking it apart and putting it back together to learn.
That was my thought. And if its just the torque converter i can replace that. If im having to replace the transmission i may as well get a 4 speed.if putting it in gear kills the motor? The trans is bad…the torque converter is locked up.
