cjkeeliii
- 3
- 0
- Thomasville, GA
I have an '85 m1008 with approx. 68,000 milies. I noticed today that it is leaking antifreeze from one of the oil pan bolts: from there it drops onto the starter, then the u joint of the front drive shaft, then onto the ground. I've checked the hoses and can only access one freeze plug on that side. Is this possibly a cracked block? I'm taking it to my mechanic Monday to have the system pressure tested. The truck has never run hot and has plenty of anit freeze in the radiator. Thanks in advance for your help.
