- 143
- 16
- 18
- knoxville tn
Have M936, speedo will work for a bit and drop to zero, then reengage for a bit, then drop out, finally pulled out gauge panel to solve this and another issue, unhooked the cable from the gauge - unhooked the other end out of the transfer case. pulled each end, the cable does not appear broken, both ends look good (not rounded out). the transfer case end is leaking oil - very little but is wet on outside of speedo gear drive, also the rubber gasket on the cable flare is shot. I have greased the fitting a few times.
so question is what is the next step to figure out, is it a bad gauge or a bad gear housing or what not? need advice before I take off the gear drive at the case end (not overly sure what to look for other than a broken gear), or get a second speedo???
thanks for any advice.
