Help with clutch problem....!!!! Please
Hottrodd789
Orlando fl
I have weird issues with my clutch on the deuce when I first take off I have clutch pedal after I shift the first time the pedal goes to floor. I did a test I can put it in fifth and it does not slip no clutch fingers are broken any ideas?
glcaines
2,393
Hiawassee, Georgia
Ditto on a better explanation.
Are you saying that when you start out in first that you have a normal clutch pedal, but when you subsequently shift, the pedal then goes to the floor? Did this happen only one time and now your pedal always goes to the floor or are you saying that every time you start the truck you only have a clutch pedal the first time? This would not make any sense. Have you checked the linkage?
m-35tom
220
eldersburg maryland
when pushed, the clutch pedal should always go to the floor. and it should always have 1" free play at the top before you feel it start to push the clutch in.
Hottrodd789
Orlando fl
The issue is the first time I put it into gear the cluch works and I can disengage pressure with the clutch pedal then I have I have spring tension on the pedal but ifi use cluch pedal to gears again the pedal doesn't do any thing I just been using the motor to switch gears I pulled the inspection cover off for the throw out bearing all the fingers are intact how close should the throw out bearing be to the cluch fingers cluch does not slip. Its weird that if the truck sites over night I can use the cluch one time. Do yogurts think I should try adjusting linkage its the only thing it can be in my eyes
DieselBob
13
Arnold Maryland
The only things that cross my mind would be the control lever(#1) in diagram 2 somehow slipping on the shaft. The fork assembly(#19) in diagram 1 slipping on the lever shaft. The symptoms you describe would add up to a bad master cylinder or slave cylinder if it was a hydraulic clutch setup. The only other thing I can think of would be the transmission input shaft nose binding in the pilot bushing in the crankshaft but have no idea how it would work once.
gimpyrobb
dumpsterlandingfromorbit!
27,785
747
Cincy Ohio
You will not be able to tell if the PP fingers are broke from the inspection plate. If the linkage checks out good, you need to pull the trans out.
poppop
39
Brooklet, Ga
I had a farm truck clutch fail a couple weeks ago. The petal felt normal but the clutch would not disengage. It was a four finger plate and two of the pivot bolts had broken out of the face casting. Not the same problem as yours but could be related. Sounds like you will have to pull the trans for a real looksee.
glcaines
2,393
Hiawassee, Georgia
I think you definitely need to pull the transmission. When you do, I would go ahead and replace the clutch and pressureplate even if they look good since the parts are cheap and you will already have expended the labor. I'm suspecting broken fingers on the pressure plate.
rosco
27
Delta Junction, Alaska
I had a pilot bearing freeze up once, and that caused the clutch not to disenguage. When you replace the clutch, replace it all. Including the pilot and throwout bearing. Its a long way in there to them.
charlietango
20
Winnipeg
had the issue where i could press the clutch in with my pinky. the truck would slip in gear however meaning the clutch was totally fried. your issue is strange if its getting power and driving normally.
