Help With Wiring in Battery Box
jim1131
35
Illinois
I relocated my batteries and removed the passenger side battery box to allow for more room for after market seats but Im not sure if I need all the power wires connected to the power strip. I know that my heater blower gets its power from there but whats going on in the panel behind the passenger seat? Other than the trans relay and probably the reset switch what else do I need there? I know that theres a technical manual and I did download it and checked for the schematics but couldn't find the one I need. The truck is a 2007 1165 model and im using manual TB 9-2320-335 13&P. Any help is appreciated, thank you in advance
jim1131
35
Illinois
This may help with the trans wiring.
Thank you for the attachment but I have all the transmission wires figured out. Theres a harness that come out of the passenger side tunnel underneath the windshield and goes all the way back to the box behind the passenger seat. It doesn't look like its part of the transmission harness and all the boot connectors are plugged but its receiving power from the power strip. Im trying to figure out what this harness is for and if I can remove it. Also I need to know where 651A & 660A wires are going to, they are both connected to the power strip.
Retiredwarhorses
4,135
Brentwood, Calif
That harness feeds the windshield deicer box That would be on the A-pillar.
