Hemtt M978 throttle pedal
colesmotorsports
33
ND
The go pedal in the Hemtt is crazy uncomfortable when ankle don't bend good anymore. Any ideas on modifying ??? It's air operated to the motor thought about putting hand operated one on , any ideas????
simp5782
Feo, Fuerte y Formal
9,339
Mason, TN
Just use a trolley valve like a semi uses for trailer brakes. It will mount on the console to your right where the 983 has its trolley
It's spring loaded so it will return to zero when it's released so that is a good thing
colesmotorsports
33
ND
Cool just what I was thinking about, was looking most of the day at different styles, this is a cheaper way
colesmotorsports
33
ND
Got the pedal moved, bought the panel and tried to use the brake valve on the center console in a comfy spot but there was to many wires or heater core in the way . Worked great just moving the pedal down. Lots of great spare parts on that panel, cheap and glad I bought that panel!!! Pedal use to sit on the black bracket above .PXL_20220701_172410666.jpg
