- 2,155
- 63
- 48
- Zimmerman MN
I'm not getting any starter solenoid thunk when hitting the start switch. I'm going down the TM troubleshooting list, battery switch is good, starter switch is good, I get the thunk from the PCB, have 24 volts to the solenoid. Want to skip ahead...... Can I bypass the solenoid somehow and apply current to the starter to see if the starter itself is okay and work backwards from there? I'm assuming at this point the solenoid is the culprit or neutral safety switch possibly.
