How full is full
m35a2cowner
Columbus, Ohio
If the outer wheel bearings are lubricated by grease, how full do you fill the differential? To the plug or within xx percent on an inch of the plug? Sorry if this question has been asked before and I missed it. Thanks
papercu
31
Baxley, Ga.
full
There is a very amazing manual over in the TM section that is listed as the LO (Lubrication Order) 9-2320-209-12-1 that is just filled with all kinds of facts like the item you asked about. Print out a copy and on those dark and stormy nights or when the wife/girlfriend has a headache, read it and all kinds of mysteries will be revealed. Now just keep this between us, we wouldn't want this kind of info released to the masses. Good luck, Wayne :D
acetomatoco
RE: How Full
Good job... my rule of thumb is that if you can reach the GL1 with the second knuckle of the middle finger, it is full...make sure the vent is working... ACE
m35a2cowner
Columbus, Ohio
Thin Grease
For a while I have been plagued with brakes that grab on the right side. I finally got up the nerve (especially after those very detailed explanations of how to do on the site) to tear down the right side and put a new Axel seal, king pin bushings and brake 4 shoes and turn drums (both sides). I already put a new master cylinder last year. For a while I have noticed an slight oily drip from the wheels. I figured it was the wheel cylinder or axle seal (Hub was loose so that is reason for bushings). When I tore it down tonight (ignore date on pictures) I noticed the grease was very runny and was inside the outer and inner axle tube (see pictures). I an thinking it might actually be what is getting out on to the shoes and causing the problem. It was out on the outer end of the axle splines. Is this possible? Also, what type of grease (available from NAPA) would be good for reassembly? And I especially want to give a big tip of the hat to Karen and Ted at Ted's Trucks who really went the extra mile to get me parts when my credit card wouldn't work on their system. Very good people and a pleasure to do business with.
m35a2cowner
Columbus, Ohio
I know the grease question might be a bit out out of how full is full but I was initially asking because of this problem. Thanks again for all the help.
