How to add a temperature guage
tgtaylor64
Florence, SC
What are the recommendations on adding a analog temperature gauge to the dash next to the voltmeter? Specifically, which one and how does it need to hook up to the engine?
Skinny
488
Portsmouth, NH
I think mine is a cheap autometer gauge. Installed with all of the supplied fittings in the driver side cylinder head all the way up front. I removed the idiot light sender since I don't trust it and would rather just look at the gauge.
Drock
12
Eatonton GA
HA! I just walked in the house from installing one:carnac:. I just bought ah cheap $18.00 Bosch from advanced. I plan on getting better ones later so this one will get me through till then. I just ran the line through the speedo cable grommet in the fire wall , to the unused port on the passenger side of the water pump. The gauge even came with the right size brass adapter. Had to swing the passenger side alternator down and out of the way. I think the whole think took 20 minutes?
tgtaylor64
Florence, SC
Just completed installing the Bosch from Advance mentioned by Drock. Very pleased. Other than having to heat the water pump plug to get it out, no problems with the install. Gauge reaches 180°F and then drops when thermostat opens then settles out to around 160°F while driving around town. Gauge rises when the engine is off to around 190°F and then drops as it cools.
llong66
kokomo, In
I installed mine on the pass. side head after getting one of the threaded blockoff plates. I had temp. bought a cheap set from summit, a mechanical OP and temp gauge and no matter what I did, I could not get the sending unit to seal. Like I said, it was cheap, the set was only $20, so other than the ones mentioned above, YMMV with the cheap stuff.
Drock, I had heard that might not be the best location, I had asked about it in a past post, I will be interested in seeing what kind of readings you get.
Check out post 6 in this thread:
http://www.steelsoldiers.com/showthread.php?129916-Possible-water-temp-probe-location&highlight=
Drock
12
Eatonton GA
:ditto: Yeah I'm getting the same readings. It hangs out at 160 do to the cooler fluid being pulled out of the radiator by the pump. I also have one of these http://www.jegs.com/i/Mr.+Gasket/72...8&cadevice=c&gclid=CJmU-s72kcICFUkA7AodEVwAmw Mr. gasket radiator cap with the temp gauge in it. After the truck warms up it sits at 180, while the Bosch gauge in the cab sits at 160.
Sharecropper
963
Paris KY
Well, if a fellow wanted to add a water temperature gauge and keep the idiot light operable, where should the sending unit be located?
llong66
kokomo, In
Sharecropper, I would try and find one of the threaded blockoff plates like I did, its the part like on the drivers side where the glow plug temp sensor is Maybe a fellow SS member has one to sell or someplace like Hillbilly wizard or Saturn surplus. Then you can just replace the one at the rear of the pass. side head. If you cant find one, you could either used the one on there or find a spare and drill it and weld a fitting of the proper size on.
Sharecropper
963
Paris KY
Will do. Thanks!
rsh4364
15
greensprings ,ohio
Or you can get a coolant crossover from a Humvee,they have 3 extra ports.One for temp gauge,one for elect.fan controller and one for an anode.2 are 1/2npt and 1 is 3/8 I think.
Sharecropper
963
Paris KY
llong66 - I am having difficulty finding that threaded block-off plate. I would rather purchase the plate already threaded instead of having to weld on a fitting. Do you have a source? Thanks for your help.
cpf240
Free in Northern Idaho
It is a discontinued part. I bought one a few years ago from one of the online chevy/gm parts houses.
llong66
kokomo, In
Sharecropper, I bought mine from a fellow SS member, maybe put a WTB ad in the classified? My only other thought would be local salvage yards, I imagine the sensor used on the civi trucks/vans is the same size.
welpro222
Bellingham, WA
I tapped and threaded a 1/8 npt autometer sender into the coolant crossover pipe towards the drivers head. That way I could keep the light and have a gauge. I also teed off the oil port and added a autometer sender there too.
cucvrus
10,225
Jonestown Pennsylvania
008.jpg007.jpgI have HMMWV coolant crossover manifolds that have 3 ports to use for what ever you want. Just like rsh464 was saying. I sold him one. Send a PM if you want one. I still have a few left.
rsh4364
15
greensprings ,ohio
View attachment 531646View attachment 531647I have HMMWV coolant crossover manifolds that have 3 ports to use for what ever you want. Just like rsh464 was saying. I sold him one. Send a PM if you want one. I still have a few left.
Im gonna get mine installed as soon as new radiator gets here,I like the 3 extra ports as I want to go electric fan eventually and want to add a sacrificial anode to coolant system.Left port for temp. sender unit,center port for anode and right port for elect.fan controller.Two things I have to change is the heater hose connection needs to be switched to a 45 to clear our alternator and water pump bypass on Humvee seems to be 3/4 hose instead of 5/8.Ill either switch waterpump to 3/4 bypass or crossover to 5/8.Anyone have a waterpump bypass thread size ?
cucvrus
10,225
Check out that box. That is the one that was lost in the great snow storm on a stranded Fed Ex truck. It is the one I sent to Greensprings OH. Do you know anyone out there. I just got it back on Friday and check out the box. Nice condition. Never hurt the manifold.
rsh4364
15
greensprings ,ohio
Haha,I was wondering if that was my first crossover,tried zooming on box to see if that was mine! CUCVRUS went way out of his way to get me my part guys.Looks like they put under rear tire for traction maybe..LOL.
