Huge mistake. I won a GP auction…. Cali FMTV Project “ ‘Merica”
NDT
6,951
Camp Wood/LC, TX
I thought your front driveshaft was bent as well? I would highly suggest you look into the u-joint puller tool, these caps can be stupid stuck in the yokes. Wasting hours pounding and cussing is not good use of your time out there.
serpico760
1,867
San Diego, CA
Definitely buy the u-joint tool. And pull both shafts. Just because it's not visibly bent doesn't mean it's still balanced. Some of these weren't well balanced when new.
I would say don't necessarily spend the money on the tool until you try it other ways. Mine came off actually stupid easy and I ended up not even really needing it. I had a standard two jaw puller that was a big one. I put two pieces of pipe around the ends and put those in the yoke holes, and pushed against the shaft and it actually came off easily. The tiger tool u-joint puller I bought turned out I didn't even need that either. Soak the pieces with something like liquid wrench give it some vibration and try it without the fancy tools first it might just work. I had way more difficulty getting the steering rod end off which took me several days of heating and pounding versus the u-joint and yoke which came out in a matter of minutes
TOBASH
3,719
Brooklyn, NY
All great suggestions and viewpoints.
Many thanks.
What about shock absorber alternatives?
GeneralDisorder
5,513
Portland, OR
Haven't encountered a bad shock yet that wasn't physically damaged. I'm sure it happens but I've not seen it. I would just source some used replacements. New shocks for our trucks has been a sticking point. There's nothing in the civilian space that really seems to be an easy drop in unless you go into the performance aftermarket and then you are talking $1000 to $1500 or more per wheel plus custom fitment - IE buy a lathe and make the adapters yourself.
TOBASH
3,719
Brooklyn, NY
My rig has a bent shock from a forking forklift at GovPlanet facility.
Same with drive shaft and tie rod
