Hummermark
- 31
- 28
- London uk
Hi I have a m1113 with the fan bolted to the water pump via 4 3/8 unc bolts there is a spacer between the fan and water pump pulley 11/8 thick it is a 10 bladed fan has any one put in a viscous hud?if so which one? The fan looks the same as the clutch fan on the humvees has any one done away with the clutch unit and put viscous hub on?
