Humvee Radio Top Pictures
Hummer Guy
807
United States Louisiana
I'm kind of curious if anyone has any pictures of what the communication/shelter tops look inside before they are demil. In mines there's a bunch of wooden structures like there was things mounted on them. I notice some of these have what look like generators or AC units mounted on them
Yes, I know my pictures are taken on a potato, so I found some other pictures on the web
Mogman
9,584
Papalote, TX
There are SO many versions of the LMS (lightweight multipurpose shelter) that that is really not a valid question, I mean dozens of different applications at least.
If your shelter has the data plates you may get close, here was mine before I stripped it, just as an example.
I am curious to see some detailed pics of the pass-through and how easy it is to get through.
Edit, that interior does not look military, where did you get the shelter? Also more pics, is yours a long or short version? (does it cover the old tail light positions)
Mogman
9,584
Papalote, TX
Now that I look at them more carefully you are showing examples of different TYPES of shelters, the last is a S-788, if the first is yours that it is not an LMS as it is more like a pickup "cap" as that one is using the original HMMWV floor, the LMS has it's own floor
Hummer Guy
807
Yea, the first one is mines, it uses the original humvee floor
Hummer Guy
807
The top came with it from govplanet, apparently its some top general dynamic makes for the humvee and JLTV, its the short top
Mogman
9,584
Papalote, TX
pretty cool, I am sure the same applies as surly there are many different applications for this cover.
