The front floor brackets are the same it's the dash mounted brackets that differ between the two types.
The original style is basically just a plastic coated spring clip. The newer style is the same spring clip but it's attached to an adjustable mounting bracket that allows you to adjust the tilt or lean to the weapon . possibly to allow for optics or rail mounted Accessories.
Check with 86humv here on the boards he may have some.
BH
