I rebuilt My AirPack(PICS)
No.2Diesel
11
Huntington, NY
...and so can you!
I realize that this isn't a very productive thread as I didn' t take step by step pics, but wanted to demonstrate that its not that bad. Plus all the pics you need are in the TM. No real surprises.
*Took about 6hrs. (not including reinstalling unit and bleeding brakes.)
*Make sure you take your time and clean everything
*My kit lacked sufficient amounts of felt material
*Got a booboo when pushing plunger into Air Cylinder
*Follow the TM!!
*My brother rebuilt his unit for the Tractor-Wrecker.
*5Ton AirPak has more parts.
*Was bleeding brakes on 819 when front hard line blew.
*Would not have known condition if vacuum bled.
*INSPECT YOUR BRAKE LINES
Manstein
Chaplain Emeritus
331
Cartersville Ga.
Nice job. Sorry about the workmans comp claim on your hand. It was also nice of your wife to let you move the kitchen counter downstairs to complete the job.
No.2Diesel
11
Huntington, NY
Your mistaken sir! :) That IS the kitchen. :p Its a sawzalled section of counter I throw around as a work table. Picture the house Ed Norton was living in, in the film Fight Club. Those are my current living conditions. 8)
Both Kits came from White Owl
Deuce:$75
5ton: $175
I think if I ever had a digit or limb severed in an accident I would start gnawing on it before the EMTs got there. The urge is too great :p
WillWagner
2,610
Monrovia, Ca.
I did one of mine when Saturn had some kits. Was fairly easy. The gaskets were hard as a rock. Just soaked them in hot water and they came back to life. Good job No.2! Sorry 'bout the oops onthe hand.
1,807
There is also a sticky at the top of the forum about air packs. I'd check it out before your rebuild.
No.2Diesel
11
Huntington, NY
Thanks Bjorn.
I forgot to mention that yes my airpak was oozing and producing a very soft pedal. I also replaced my master cylinder too. Huge improvement resulted.
It is usually mentioned that some tool oil be added to the air cylinder. Whats not mentioned is the quantity and the frequency. Anybody got some ideas?
jwaller
19
Columbia, SC
Is your pedal now high and firm? not easy to push? I'm trying to decide if I need to go thru mine or not. It just seems much harder than the 5T
