If you buy an armored MTVR...
MTVR
741
Waco Texas
...they don't bolt the seats or seatbelts down properly when they remove the armor prior to sending them to auction.
We found our driver's seat loosely (and I mean LOOSELY) bolted down with only two of the apparently four mounting bolts. The other two were missing.
The female halves of our two passenger seatbelts, were not bolted down at all.
And out of the 19 original mounting bolts, our double passenger seat had only ONE bolt holding it in, and a couple of other incorrecrtly-sized bolts just sitting in a few other holes. There was even a broken-off tap jammed crossways in one hole. And it was installed at a forward-leaning tilt, because the rear rail of the seat mounts to a raised flange that is part of the cab, and the rest of the seat is supposed to rest on armor that isn't there anymore.
Today, my wife and I removed all the mismatched and incorrectly-installed bolts, moved the passenger seat forward enough to reach the mounting points for the female halves of the two passenger seatbelts, bolted those seatbelt components to their mounts with grade-8 hardware, and then installed all 19 mounting bolts with Nylock nuts, and used large nuts used as spacers to make up for the missing armor.20200427_184946.jpg
Elijah95
Certified Rookie
1,239
1,183
Georgia
So on my unarmored mtvr, there isn’t anything between the passenger seat. From the factor it sits slap down on the floor, basically yours but without the nut in the middle.
Seat belts? Who uses them anyways rIgHt??
MTVR
741
Waco Texas
The seat bolts down to a rail along the back edge, that is part of the cab. The passenger seats for the armored MTVR are shorter on the other three sides, so that they sit flat on the armor. Once the armor is removed, the seat won't sit flat anymore- it rests on the rear rail, and then tilts forward until the front rail touches down.
MTVR
741
Waco Texas
I suspect that the MK23A1 (the Ready To Accept Armor version) comes with the same passenger seat box as my AMK23 (which was born with armor), and that the MK23A1 leaves the factory with some kind of spacer rails underneath the passenger seat, which are discarded if/when armor is installed. So the only time we'd ever see those spacer rails in the wild, would be on a MK23A1 that never received armor.
MTVR
741
Waco Texas
My seat air switch came today, so once I was able to air the seat up, I removed the only two bolts holding the driver's seat in. They were incorrectly sized, installed wrong-side up, and the threads bottomed out before the seat was even held down. Then I mounted the seat properly, by installing four correctly-sized bolts with washers and Nylock nuts, right-side up.
