- 3,222
- 3,260
- 113
- NORTH (Canada)
Noticed what I believed to be tic-tic-tic sounds from valves, especially when cold and under load (e.g. accelerating). It sounds a bit like what you hear in an old pickup truck where the valve train is a little noisy and clatters when the engine bogs down.
So, set valve lash today.
Nothing way out of spec, a couple of tight-ish valves. Sound has not changed. I remembered that I had also swapped the single hole for double hole injectors and these were overhauled by a diesel shop and set to max opening pressure. I was thinking that what I am hearing could be the injectors, not the valves.
The truck doesn't miss a beat, fires as soon as you think of pressing the button, smokes little and has no driveability issues. If it ain't broke, don't fix it.....don't want to tear into something without good reason.
What do you think?
What do you think?
