abfisher1798
- 87
- 28
- Blythe, California
I hope to make this easier by checking with you all first....
The wire ID on the back shows 514 and 515. The Wire ID Tag sheet indicates "514 Dimmer Switch to B.O. Upper Beam (IR)" and "515 Dimmer Switch to B.O. Lower Rear (IR)".
I assume they are ground and power, but the Tag sheet makes me think otherwise.
Any guidance is appreciated. Thanks.
