is this going to be a good rig?
I am about to trade my jeep for a 84 k5 diesel dana 70's lockers front and rear 45" tractor tires which I am going to get some regular 42" tires so I can run it on the street, just wondering if these things are tough? How is the 6.2? I have always heard they are junk....is there anything that noramally messes up on them? here are some pics
tsmall07
Springfield, VA
I'm pretty sure there's no such thing as a dana 70 font axle, so I imagine you mean dana 60/70. If those are the axles, you'll have to take it kinda easy if you don't get chromoly axle shafts and big joints in the front (especially with a locker). The rear should be fine. What kind of lockers? Its too tall for me, but it all depends on what kind of wheelin you do. Lower with big tires and hacked fenders is better. (unless all you do is mud bogging) The diesel will also be good for wheeling because its an injected system that can run at steep angles . (although at the angles that would choke out a carb, that truck would flop anyway... :lol: )
1,807
70 fronts exist. In stock for you can tell them by the rear mount tie rod. That does look like a 70. As far as the 6.2, short on power but still a decent low buck diesel.
tsmall07
Springfield, VA
Re: RE: is this going to be a good rig?
Recovry4x4 said:
70 fronts exist.
Wow. I think the same advice goes re: axle shafts, though. Apparently they still "only" have 35 spline shafts. 46" tire should be right on the limit for that axle.
AJMBLAZER
Paducah, KY
This question would be better asked over on www.ColoradoK5.com .
Looks like a big mud truck. Not my choice and I bet those axles are on the ragged edge of surviving with those tires. Bet they're a lot heavier than similar sized Swampers.
The Dana 70 front is marginal depending on what it came out of...the newer ones are actually an improvement over a Dana 60 but they're all out of larger trucks like shown above. The older ones actually had smaller components than typical "light duty" Dana 60's.
