- 2,869
- 27
- 48
- Delta, PA.
John just called me he off of I-81 in Pine Grove,Pa. He is too far away for me to help.He has a freeze plug problem.His cell # is 518-424-8455
Info passed on to John.I had the one above the alternator blow out on a trip and used a rubber expanding one since I had limited tools with me. It held for the trip until a permanent repair could be made. The local napa store had it in stock and it seemed like it was 2"
Might I make one more recommendation to the JB weld thing? Use a piece of saran wrap/plastic over any vertical seams. JB weld will try to level/run as it sits. The plastic over it will keep it in place. Also spray it down with parts cleaner before adding it.On phone with him now.
He has some help coming.
I will be on standby ready to roll if they need anything. I'm about 2 hours away from him.
He lost a freeze plug near the exhaust manifold. Has one coming and will see if he can get her back to operating condition.
Will update as news comes in.
UPDATE
Plan is to JB Weld over the old plug and let it harden overnight before continuing on. He is in a parking lot off of the interstate.
Additional Thanks need to go to Papa Bear for helping with repair suggestions and recommendations!!
Karl
JT mentioned he would do that when we talked today. He said there were No cooling issues prior to the leak being discovered.Consider running with a lose radiator cap to relieve pressure against that repair. Safe journey!
