Just picked up. 1986 M1028A2
my69camaro
La Porte Indiana
Picked this bad boy up Friday morning. Drove all night Thursday from Indiana to Pennsylvania to get her. Local fire departments brush truck. Had a big work bed on the back, they just snipped all the wires so that kinda stinks. Otherwise it's a pretty nice, solid seeming truck. Supposedly 10,200 original miles but who really knows with mil stuff. Can't decide if I should paint the bed red or go back to camo.
Tag says it's a m1028a2 but it has a 208 t case. All I've read said it should be a 205??
jcollings
347
Jupiter/FL
Looks like a M1031 with the modification that's what the tag says. added the 2 wheels (dually) makes it a M1028 now
Sent from my SM-G975U using Tapatalk
Saberr
84
Temecula,Ca
Nice, don't see many of the bigger cucv boys. Bumber they cut the wiring, easy fix though. I personally like the thought of going red for fire truck, alot camo out there. Then you can also say you own a fire truck and not be lying either.
jcollings
347
Jupiter/FL
Yes I've got the very same truck except for it's just a cab and chassis had the maintenance Box on it which was removed it is camo though
my69camaro
La Porte Indiana
Well I tried to get myself tail lights today. There were four colors being used on the old bed setup and a four color plug on the blue bed. Matching colors; a yellow, a green, a dark green, and a black or maybe dark gray. Butt spliced them together (all switches off, including mil toggles) and hooked up a ground wire to the frame that was coming off the bed... No tail lights, and now I have no front lights (they had worked before).... Looks like the 30amp fuse is blown in the fuse box. Hopefully grab a fuse tomorrow morning. But what else am I missing.
M813rc
2,716
Near Austin, Texas
As an M1028A2 converted from an M1031, yes, it should have had an NP205 transfer case because it was used to run the compressor and generator in the original maintenance box.
But unless you want to run those off a PTO, or are super concerned about originality, you should do fine with the 208.
The M1028A3s were all converted from trucks with that transfer case.
You likely already know this, but there were no factory US military dually CUCVs, all were converted from single rear wheel trucks while in service. GM made a complete conversion kit, supplied in a big crate.
My M1028A2 started it's life as an M1031 too.
Cheers
