- 34,012
- 1,807
- 113
- GA Mountains
So, I have this M51A2 with the LDS. It had sat for some time so when I got it, it was not running. Prior to it's slumber, it was a dependable runner.
I found that the fuel shutoff rod was frozen in the pump. I pulled it out, took it apart and freed it up. Put it all back together and viola, she starts up pretty easily. Keeping it running was another issue, it just dropped off under 1000 RPM.
Since then I've replaced the fuel tank, completely cleaned and flushed the in tank pump which is running. Replaced all 3 fuel filters and made several attempts to combat the problem with idle screw adjustments. The fuel is fresh, purchased it today. Nothing has worked so far.
Today I ran it for quite a while hoping maybe a heat/ cool cycle might make a difference. I've not fooled with fuel rate at all. I know there are more adjustments such as the droop screw but I don't want to fool with things I'm not yet familiar with. I do not think the FDC has been bypassed and I have no idea if it may play a part in this. If anyone has any ideas, I'd sure appreciate it.
