Leaking Rear Wheel Bearing Seals - another thought
houdel
9
36
Chase, MI
It seems like most every page on this forum has at least one posting about leaking rear wheel bearing seals. Often the problem seems to stem from the cork insert which is SUPPOSED to keep diffential oil from bypassing the outer seal and outer bearing and then getting into the bearings, then finally blowing the inner wheel bearing seal.
This cork insert seems hard to find at times, as there are many posts about making your own inserts from cork sheeting and Chevrolet valve cover gaskets.
How about finding a large, industrial sized O ring to replace the cork insert? Seems like if enough differential oil gets in there to lubricate the insert and keep IT from breaking up, an O ring should hold up pretty well, IF you can find one big enough. As the cork insert is 1/4" x 7/16", maybe a pair of 1/4" thick O rings of the proper diameter might work. Since the inner surface of the cork insert has to be tapered anyhow, the O ring should be a good fit and may even work better than the cork insert.
Has anyone tried this? What are your thoughts?
Link to PS Magazine article on oil seal leaks:
http://www.steelsoldiers.com/module...ile=index&name=gallery&include=view_photo.php
Link to Technical Article on oil seal leaks:
http://www.steelsoldiers.com/index.php?module=pagesetter&type=file&func=get&tid=3&fid=file&pid=7
Scroll down to the last illustration in the TA for a good cross section view of the seal/bearing area.
wallew
houdel,
I like the way you approach this problem. I will start looking for the right sized O-Ring.
I'll get with Randy Barnes and see what we can come up with and report back. I'm getting ready to do the 'super single' conversion, so now is the time.
jim
houdel
9
36
Chase, MI
Right you are - I misread the TA & PS articles. I thought the cork seal went around the entire periphery of the bearing, but it only fills the keyway. But I suppose you could still fill the keyway with 2 pieces of 1/4" O ring cut to 1/2" long (since it appears the slot we are trying to fill is 7/16" wide x 7/16" deep) and crammed into the keyway. The outer seal & adjusting nut should squash that rubber into a nice tight seal.
