LED issue
twisted60
241
Jupiter, Florida
Stumped, I just installed LED brake and turn signals in my '86 M998 but,,, when I have my head lights on the turn signals don't work.
With headlights off everything works perfectly. I replaced the bulb in turn signal switch with an LED, I have LED marker lights, LED headlights, LED brake and turn signals, so...what did I miss ?
tobyS
815
IN
Did you use a 50 watt resistor on the turn signal to simulate the heavier load of incandescent?
Retiredwarhorses
3,775
Brentwood, Calif
Your problem is the turn signal flasher unit.
It’s made for incandescent lamps.
you need to put an LED bulb in the flasher unit.
this is a common problem, that or buy the truklite flasher unit for
$300 bucks...
tobyS
815
IN
Yes, changing the flasher unit to one that works for LED is good but using a 50watt resistor makes a standard flasher think there is a bulb with the draw of incandescent. They are about $6 each and only need to go on the turn signal. Everyone selling LED's has them.
twisted60
241
Jupiter, Florida
Where would I install the resistor ?
I think I have a LED compatible flasher unit some where in my spare parts supply but I'd like to try the resistor first.
Thanks for the help
springer1981
1,147
Maine
Thanks for the help
If you have the LED Flasher why would you want to use a resister to INCREASE power draw so that it flashes? One of the benefits of the LED's is they use less power. The resister makes the LED use more power so it can operate a bi-metal mechanical flasher.
tobyS
815
IN
The resistor installs between the + and - . Springer is right, it brings the load to where a mechanical system can "see" it.
