LMTV CTIS UPGRADE
Stellaevil
Michigan
Dana will be releasing a new CTIS Wheel Valve design that will be compatible with the LMTV systems. The valve will only be sold to OEM for current production. However if there is enough interest we could market a rebuild kit. The advantage of the replacements parts is a new diaphragm that will perform to -35 deg F. and last much longer. The new design is also impervious to water and moisture. Please let me know your interest in this kit and what a fair price point might be. The kit would include the following: New vented lid w/4 screws, new diaphragm, new spring, and a small bracket to protect the lid vent. As this would be purchased through a dealer I could be $100 per valve retail.
94
39
San Diego, CA
Interested
Sent from my SM-N986U1 using Tapatalk
19,037
That makes 8 including you Stellaevil . Nine if you add me. Also interested.
Remember too that some trucks need 4 and some will need 6.
TomTime
1,666
MD.
Did this ever happen because I would be in.
I was in when it was first brought up and I’m still in, but haven’t heard anymore about it.
Not trying to discredit or be disparaging to anyone, I would help if I knew how I could.
I hope it’s still in the works!
33
13
florida
So after many hours with Parker’s military engineering department we are going to try to build a complete replacement kit. New controller, valves, and most importantly all the wheel valves. Might take some time as we are designing it and testing from a system they designed for the hummer, But it’s in the works.
ramdough
1,727
Austin, Texas
I am interested.
