- 6,741
- 158
- 63
- Stratford/Connecticut
Made a new site www.lmtvparts.com
Lots of lmtv stuff in one thread. MAKE SURE YOU SCROLL DOWN FOR MORE PARTS LISTED.
Door parts: Lock blocks and lock mechanisms with rod clips as pictured. Left or right side. 40 dollars each. I have the screws that hold them together 2 dollars each. Inside door release handles 5 bucks each. The spline is slightly small so you have to work it on and tighten down with your mounting screw. Window cranks 5 bucks each. Door pull handles 35 for the pair. They only grab 2 of the 4 original screw holes and you will have to provide your own screws. The originals are too short and you dont want to go too long and hit the window. SHIPPING IS A FLAT 8 DOLLARS FOR AS MUCH OF THE ABOVE LISTED PARTS AS YOU WANT. Prices are paypal gifted/check or regular paypal and add the 3 percent fee in.
JUST IN NEW WINDOW REGULATORS LEFT OR RIGHT 125 each plus shipping!!!
CTIS controllers and programming: I offer programming for your ctis controller its 75 bucks including return shipping. There are 3 generations of ctis controllers. One and two are green and 3 is black. Only two and three are programmable. I have programmable ones in stock. Contact me with questions
Trans ECU: I can program WTEC2 and WTEC3 transmission controllers and can provide good tested units ready to install. I can also test yours if you are trying to diagnose an issue.
BEST CONTACT: email will atpawnking dotcom
