Overdrive
- 83
- 28
- Wentzville, Missouri
This is just an FYI post to show what it looks like behind the heater and what the major stuff is behind there. I took this in the middle of my Gen2 AC install so there are huge holes that I had to drill in the cab floor that won't be there on a stock truck.
Just in case you were wondering what's behind the heater...
This pic shows the 80mil soundproofing I added under the heater and against the front firewall. If you look closely in this 2nd pic you can see the top of the Charge Air box VERY close to the underside of the cab. Mayor pucker factor drilling out those holes that close to disaster.
Hope this helps somebody.
OD
OD
