Looking for a Mechanic in the Baltimore MD area to work on 1985 HMMVW electrical
redlion42
Balitmore, MD
Have a 1985 HMMVW, 24V system and it has an electrical issue. The lights aren't working! Need to get it repaired to obtain Maryland Inspection to get it on the road. Haven't been able to find a local mechanic who will touch it. Appreciate any help & suggestions.
KansasBobcat
San Antonio, TX
Look at T M9-2320-280-20-1 page 2-56 and try following the flow chart Read thru page 2-66. You might print these pages and take to mechanic and they might be more willing to help you. I always do this. Good luck,Bob
Jakelc15
37
Hanover Pa
I'm probably farther away than Ollie, but if he can't get to it let me know. I'll work on it for you or I have a buddy that's really good with specialty vehicles in Severn MD.
CARNAC
The Envelope Please.
620
Corpus Christi, TX
Jake also has a tractor-trailer that can accelerate while going uphill at a 90 degree angle. Just look at his avatar.
Retiredwarhorses
4,135
Brentwood, Calif
Be more specific...what light? Have you checked the bulbs on affected lights? Or is it just all of them? If all of them its a
Possible bad 3 lever light switch...also make sure the lower left lever is set correctly. It kills the headlights even if the upper right switch is in service mode. I have replaced many 3 lever switches here in the shop, all causing various issues.
disconnect the batteries when replacing.
