- 303
- 391
- 63
- Geographical Center of Virginia
Not so sure that's a good spot to connect to. Issue at hand is that lamp lead (#40 x) has a "bright - dim - off" resistor in the lighting switch. Its resistance was selected to do the bright - dim based on a couple of panel incandescent bulbs used in the day. Later (hummwv) with LED in the shifter no big deal. You should notice that it doesn't (much) bright - dim. This is do to shifter LED's very low current draw, it's Internal current limit resistor and they are forward biased pretty good for lots of light. TMII've got LEDs as my backup lights and purposely wired them into the system so that I would have the ability to leave them off if I wanted to. I picked up the power for them from the connector for the legend lighting in the shifter. It's right there at the reverse light switch and meant I didn't need to run another wire into the cab.
You are incorrect. There is no #26 in the harness where it screws into the light switch. The correct horn wire is 467A.#26
Was half asleep when I looked it up in the TM, CAMO
