sandcobra164
- 295
- 83
- Leesburg, GA
I've got a CUCV at work that is losing it's prime when it sits overnight. The shop guys have tried replacing the fuel filter, tightening some clamps on fuel lines but the problem is still there. The truck is another one of those Norway Cave trucks with less than 4,000 miles on it. My personal M1028 and one other at work do not have these issues but #3 does. What are the common places to check on a CUCV for air to infiltrate the fuel lines. As a side note, once primed, the trucks gives no trouble what so ever running, shutting off and restarting within an hour or two, and will start right up in the morning till it hits the air bubble. Then it starts with extended cranking. Glow plugs are good and no fuel leaks that we can find.
