M1008 Starter runs without key on.
Camolad
OTTAWA, Ontario
Good morning all.
As soon as the batteries are online the starter powers on. After troubleshooting, I found constant power to the under dash ignition solenoid. Is there anything else in the ignition circuit other than the Key switch itself?
cucvrus
10,432
Jonestown Pennsylvania
The under dash relay is stuck. It needs replaced. Often a result of ecssevive cranking with low amperage batteries. Get a new relay that is compatible and fix the hard start condition,get
cucvrus
10,432
OK. You could have a shimming issue with the starter or a starter stuck out in the ring gear. I would loosen the starter bolt's and see if the starter retracts. Without seeing it, it's a crap shoot. Good Luck. Disconnect the batteries before doing any starter work.
